Here's the deal. I'm sure someone on here has gone through a similar situation. A 1964 D-100 didn't come with fuses, fusible links, relays or much of anything. No dome door switch, map, backup lights. No neutral safety, horn, radio, but did have a 2 speed heater. Get the picture and setup for my questions. None of the gauges or light switch will be reused. I'll probably retain the wiper and cab dome switch. My eventual plan is modern AC, stereo, gauges, led lighting and maybe cruise control. I'm thinking an 18-21 circuit universal wiring harness. I have an electronics background and I'm pretty good at wiring. It doesn't scare me ripping it all out since I have to anyway. The truck has a mild 440 and 727. Don't hate me but, some of the universal harnesses state they work with GM/Ford and Mopar but, list GM connectors. I plan on using HEI, universal gauges but, the alternator/charging undecided.
Questions: Is there some reason why I should get a Mopar specific harness? Any harness recommendations for a complete rewire? Thanks Craig
