My son does a lot of honing. He uses a patterson power hone. A motor just came in to get honed for new rings & pistons. 2017 Lexus. The super charged it and over boosted it and broke the ring lands.
Piston to wall had need to be opened up. After it was brought to size with mains torqued and torque plates installed there were still vertical scratches in the outer cylinders.
The cylinders had an open deck and egg shaped the outers from boost. This would have never been found with a ball hone. The motor will be taken to the next bore. The owner bought 12 std. custom made pistons before he brought it to us. What a waist of $$$$. They will not take custom parts back.
My advice to you is. Find a shop with a power hone. Be exact an egg shaped bore gets worse when hot.
