danmax
First I have to admit I am by no means an expert on carbs so would like some advice please
I have this 950 Holley built some years back for a Big Block and itds . Been suggested On here this could work on my 360
Specs of engine:
360 plus 40 thou using 340 rods and pistons (modified)
I think that makes it about 372ci?
175cranking psi = runs fine on pump fuel with34 degrees total
240 @50 sig erson 3h cam
Rhoads lifters
Msd ignition
ported J heads 2.02/1.60 ( painted red RRR ;)
Match ported victor 340 intake
2800 stall
full manual 904
TTI headers (RHD) and 3 inch dual exhaust
3.9 diff gears
Oh and its a 67 Barracuda Fastback and is a street car
What changes would i need to make to the carb please - build sheet attached
Specs of engine:
Rhoads lifters
Msd ignition
2800 stall
full manual 904
3.9 diff gears
