Ben A...
Noob alert.
I have an LA360 with powersteering, no A/C.
But the current pulleys and waterpump are for an AC car. (4 groove crank, 2 groove waterpump pulley w/ 6 vane pump)
To avoid any cooling issues I'm going to change the waterpump and pulleys.
I'm just a little confused on best layout for the VBelt.
Do I run a 2 groove crank pulley?
1 belt to crank-alt-waterpump
1 belt to powersteering
This kit would work? Small Block Pulley Kit
Or is there a better layout for the belts? Because there are a lot of options..
Thank you for the help.
Ben
Ben
