gm1236
69 340 GTS, intake bypass hose nipple is much small then the hose nipple on the water pump. This Is a cast iron manifold and steel water pump, could be a Milodon, not sure. Is there a magic hose to fix this? Water pump was recently replace, not sure what happen to the old one. This wasn’t an issue with that one.
