There are different holes in the core support uprights ever year from 67-69. I first noticed this when I bought a 69 Dart in 1994 and the headlight bezel was offset on the drivers side. The PO had put a 67 fender on and tried using the 69 bezel, you can see a 3/4" gap from the grille to the bezel. If I can find the photo's I took back then it is easy to see the differences from 67, 68, and 69. If I can't find them I can take new ones since I have all three years currently in stock..
