Slant Six Bumblebee
My dome light wont turn off. how is the circuit regulated and what turns it on. I dont think its my door switches.
this may be the problem the head light switch is having issues and none of my gauge cluster lights will turn on.The dome/ courtesy lamps are all fed with hot 12volts, an insulated dual contact socket, and to turn them on the yellow wire coming off the second contact is grounded. Check your door switches, and the headlight switch. "are you aware" that when you twist the headlight switch far to the left, it activates the courtesy lamps?
If you have a (optional) map light switch there might be something going on there
Sometimes the plug that goes on the switch overheats and melts . I've had this happen on 2 Darts in my lifetime. Replaced switch and plug housing. A lot of power goes through the switch and causes heat. Do the headlight relay kit after you repair your switch and plug housing.
Your housing may look like this.
