SS Lancer
Thank you SirLash chart.
The four position method is ok for cams up to 290 @ 050 duration. Bigger than this should use the eight position method in post #1.
WOW now thats a Camthink chrysler said that too .
Altho we used the 4 pos. method on a 785 lift cam dynamics roller , had no problems , -except traction.
Are the 4 position method prints still available ?
ThanksThe correct way for all , Very large rollers or mild flat tappet is this procedure below
Setting the exhaust lash > turn the motor until the intake is fully open when it just starts to close that is when you adjust the exhaust valve clearance.
Setting the intake lash> Turn the motor when the exhaust just starts to open that is when you set the Intake valve clearance.
That decal ? Peel it off and put it with your collection of DC parts.
The method I described above is called the EOIC method (Exhaust Opening Intake Closing) Suggested by all cam manufactures. Here is a video from Comp Cams.
There are lots of 'correct' & 'fool proof' ways to adjust lash.
The one I mentioned in post 24 comes direct from Chrysler & is also correct & fool proof.
It is also the quickest & easiest with the least amount of wrenching.
Here it is. Ensure the zero/TDC mark on the dampener is accurate. Adjust two intakes & two exhausts at each timing position.
#1 TDC: 1,7 4,8
rotate 180: 1,8 3,6
rotate #6 TDC: 3,4 5,7
rotate 180:5,6 1,2
Done!
Yup, the Mopar Performance method is a correct and fool proof way to do it. Rotate right to the lines on the balancer and check. There are other acceptable methods, so long as you are checking the valves with the lifter at the exact same spot on the lobe every time. I’d like to hear what someone thinks is wrong or not correct with the MP method.There are lots of 'correct' & 'fool proof' ways to adjust lash.
#1 TDC: 1,7 4,8
rotate 180: 1,8 3,6
rotate 180:5,6 1,2
Done!
Well if your dealing with a balancer that is not marked at 90 degre increments, it would be difficult to do. Don’t you think?Yup, the Mopar Performance method is a correct and fool proof way to do it. Rotate right to the lines on the balancer and check. There are other acceptable methods, so long as you are checking the valves with the lifter at the exact same spot on the lobe every time. I’d like to hear what someone thinks is wrong or not correct with the MP method.
Easy! Then you slapped on the MP timing tape!Well if your dealing with a balancer that is not marked at 90 degre increments, it would be difficult to do. Don’t you think?
Let’s think for ourselves here a minute and address the “cams of today” and “advance/retard” built into them statement before we run off enlisting answers from others:Well I asked my son. Why it is not advisable to use the mopar performance method for valve adjustment?
I use to have that same sticker on my Duster when it was white years back, And I used it.
He said the reason that method is not used anymore is because the cams today have advance and retard built into them. You probably can use it with old profile cams. He said that method is a thing of the past.
I am going to ask him to show me the difference the on next motor with adjustables. I think a mechanical lift BB ford is in one of the mills.
Most all race shops I have been to use the EOIC method now. I always bring up the sticker I used and they just laugh. You can see the sticker between the wiper motor and the heater hose nipples on my car.
I’ve slung more of those off than I can count.
Install it, mark the actual balancer as needed.I’ve slung more of those off than I can count.
You shouldn’t And the way I do em I won’t. No matter how much those big race shop guys might laugh. Never liked those type of people anyway!I’m 66 years old, why do I want to change the way I adjust valves now?
My son sent this to me .
Really, the toughest part in the whole process is determining when the lifter for the valve you are checking is actually on the heel of the cam lobe and not starting to ride up the opening ramp or off the closing ramp, which would give you a false lash reading. But there’s a great trick to always make sure you are checking lash at the exact right time in the engine’s cycle, and that’s called the “EOIC” method.
EOIC stands for Exhaust Opening, Intake Closing. In other words, when working with a pair of valves for one cylinder (one intake and one exhaust) you can know when the valve is on the base circle of the cam by the action of its mate. When the exhaust valve is opening, you know that the intake valve will always be closed. And likewise, when the intake valve is closing, you know that the exhaust valve will always be closed. This is true no matter the number of cylinders or the cam’s specs, including lobe duration and separation. Heck, it even works with those overly complex overhead cam engines your Blue Oval friends and import fanatics spend their time with.
