Here are the dimensions of the stripes that I received from PlumCrazy340 late last summer. I had a local vinyl shop cut these dimensions out in matte black and installed. They look close to original and if I want to remove at a later date and can peel off. I wish I had a picture for you but the only one is in my avatar. I did not continue the stripes or paint into the cowl area. A Big Thank You to PlumCrazy for getting this measurements for me! The graphic shop had no problems cutting them out!
[/quote] from PlumCarazy: ok, standing in front of the car. driver's side hood edge to pinstripe- 1 3/8" body color, then 1/4" pinstripe, then 3/8" body color, then 24 3/8" blackout, then 3/8" body color, then 1/4" pinstripe, then there is 2 3/4" body color down the center of the hood between the stripes. Very important, if you have hoodpins, the outer edge of the main blackout will line up with the outer edge of the hoodpin bezels. Also, the body color in the center between stripes is only on the hood, do not continue it up the cowl. Only the outer edges continue up the cowl to the windshield. if you have hood front edge moldings, the stripe's front outer edges{front hood edge is not straight across}are 1 1/2" away. if you don't have the molding's it would be 2 1/4" away. If you have any questions with understanding these measurements, let me know. I know it sounds confusing.
Hope this may help! Good Luck!
