[FOR SALE] 1.03 torsion bars with grease boots
Kern Dog
Build your car to handle.
Granite Bay CA
I have a pair of A body 1.03 torsion bars and grease boots. They are USED but have been marked for L/R prior to removal. Unknown manufacturer but stamped in the ends are the numbers 35.8 and 1.03. $140/pair
Northern CA
Pay by PayPal
More pictures available upon request.
Standard ride height or lowered? Were were the adjustors at ride height? I aon't want to lower my car any.
I'm not sure I inderstand the question. These were in a 73 Dart that had a 440. The car had no engine when I got the car. The front end was up high since the weight of the engine and trans were not there anymore. The LCA adjusters were even with the bottoms of the control arms.
A better question might be "Are these T-Bars Indexed? This is where the hex at each end is different, allowing the car to sit the stock height without having the adjusters bottomed out or sticking below the LCA. In this case, I'd say that these are right for maintaining stock height with the extra weight of the 440 but may require backing out the screw a few turns if you have a small block.
Correct me if I wrong: IIRC, most all aftermarket 1.00"+ bars are not clocked/indexed.
We went through that misunderstanding with PST's bars awhile back and they had new 1.03bars made with factory indexing, but never changed the info on thier website to reflect that fact.
The way to tell if the seller's bars are factory indexed is that the hex's on the ends are offset in relation to each other.
(both ends different if layed on a surface)
Unless I am mis seeing the OP's blown up and lightened, the are not factory indexed but zero clocked like the old PST ones were before they had the new ones made.
These are zero clocked (not factory indexing of the ends) and designed to lower the car.
Note how both ends of the bars are laying on a flat of the hex.
I will have to check the indexing when I get back out to the shop today.
I have checked on shipping to as far away as Florida and ohio. It is $37-38 due to size and length. I've had offers as low as $100 shipped. Thanks, but if I dont get close to my asking price I'd rather keep them and use them myself later.
Didn't mean to mess up your sale Kern Dog, but hopefully that information will save you some headaches down the road.
Okay thanks. I've never priced them, I just recall how expensive the MP ones were.
These have been SOLD. Thanks, Greg
