1/2 inch Feed and Return line recomendations
Fuel and Air Systems
  1. Walker434
    Walker434 Well-Known Member
    832
    425
    Aug 29, 2012
    Nashville, TN
    Local Time:
    11:21 AM
    I'm adding a Procharger to the Dart and need to upgrade my fuel system. I'm going with a 1/2 inch sending unit in the original location in the tank. I'll also be adding a bung for the return line. Using an electric pump then Need 1/2 inch feed line to the boost referenced pressure regulator.
    I'm debating between aluminum lines flared to us AN fittings? Push lock line and AN fittings? Steel braided lines with AN fittings?
    I'm new to this and just looking for people's thoughts on cost differences vs benefits ect. Any help is appreciated.
  2. roccodart440
    roccodart440 Well-Known Member
    5,099
    4071
    Apr 19, 2010
    Local Time:
    12:21 PM
    I'd run hard line and the braided towards the ends. Saves money. You don't need braided the whole way. AN fittings of course. You also don't need a 1/2" return, just the feed line.
    • Like Like x 1
    • Walker434
      832
      425
      Aug 29, 2012
      Nashville, TN
      Local Time:
      11:21 AM
      Yeah I was looking at the aluminum 1/2 inch line. Pretty affordable but then you have to buy the $100 37 degree flare tool to use AN fittings. Oh well I'm sure I could use it in future projects
      • Like Like x 1
      • roccodart440
        5,099
        4071
        Apr 19, 2010
        Local Time:
        12:21 PM
        Very true. Maybe going AN the whole way would be equal after all.
      • mopowers
        mopowers Well-Known Member
        3,994
        1144
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        9:21 AM
        No need for a special flare tool. The aluminum line is so soft, if you flare them to 45 with a traditional flare tool, they with seal fine when tightened.
        • Like Like x 1
        • Agree Agree x 1
        • Wicked31
          Wicked31 Well-Known Member
          150
          68
          Oct 22, 2015
          Morgan Hill
          Local Time:
          9:21 AM
          Aluminum line is a pain in the a$$ to route properly without kinks. Braided is too expensive. I ran some 1/2 blue Parker high pressure fuel line from summit.
        • sireland67
          sireland67 Well-Known Member
          8,069
          2122
          Oct 27, 2010
          WV
          Local Time:
          12:21 PM
          To connect the hard line to AN line, they sell "tube to AN" fittings.
          • Agree Agree x 2
          • Like Like x 1
          • SLOPAR72
            SLOPAR72 Well-Known Member
            1,402
            701
            Jan 5, 2016
            Richmond, VA.
            Local Time:
            12:21 PM
            Can you get Nicopp in 1/2"?
            Yep... Amazon has it. Easy to bend yet rigid. I would go this route before braided line because of crappy ethanol and what it does to the linings of braided hose.
            JW
          • sireland67
            8,069
            2122
            Oct 27, 2010
            WV
            Local Time:
            12:21 PM
            Summit sells lined braided line that fuel will not eat.
            • Like Like x 2
            • Walker434
              832
              425
              Aug 29, 2012
              Nashville, TN
              Local Time:
              11:21 AM
              Thanks for the replies guys. I'm going to look into all these suggestions. I'll let you know what I decide to do. May be a week or two before I get to work on it again
            • oldkimmer
              oldkimmer FABO Gold Member FABO Gold Member
              10,907
              1585
              Nov 11, 2006
              Kindersley, Saskatchewan,
              Local Time:
              11:21 AM
              I run Aeromotive braided hose. Supposed to be the best.number 10 in and out. Also an Aeromotive 2000 pump. My car and life are worth it. Kim
              • Agree Agree x 1
              • famous bob
                famous bob mopar misfit
                12,530
                3481
                Aug 14, 2011
                okla
                Local Time:
                11:21 AM
                There is alcohol proof fuel line out there. My fast 2.0 fuel inj. system came w/ enough for a feed line. I had s/s braided ptfe lined in already, which I used as a return/back into the 3/8 pick up w/ the sock cut off. My dual outlets are on the back bottom of the new stock tank.
                • Like Like x 1
                • Walker434
                  832
                  425
                  Aug 29, 2012
                  Nashville, TN
                  Local Time:
                  11:21 AM
                  Just giving an update. I ended up going with aero motive -8 feed and return lines with AN fittings. Installed a 1/2 sending unit in the stock tank and installed a -8 bulkhead fitting for the return. Tank is back in and next up is running all the lines.
                • RustyRatRod
                  RustyRatRod 30 Degrees Outta Whack FABO Gold Member
                  51,146
                  18182
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  12:21 PM
                  I much prefer steel hard line to aluminum. Just personal preference. It's much more robust.
                  • Agree Agree x 1
