I just put a 1.6" band in my A500 which is basically a 904 with an overdrive on the back. It fit fine, bit haven't run it yet. Still doing my swap from 904 to A500Question, Can i use the 1.6" wide band on a regular 4 disc front clutch retainer.
Thanks for replying ,I just put a 1.6" band in my A500 which is basically a 904 with an overdrive on the back. It fit fine, bit haven't run it yet. Still doing my swap from 904 to A500
The A500 & 999 have a wider front drum to accept up to 1.75" wide bands ' i think' .
