Snake
Mopar Nut
IS 1/8 STEEL good to use for the brackets for the rear bumper,in the pic is my Left side temp plate.Whatsssssssss your thoughts.
Thankssss buddy.Don, I think 1/8 should be just fine as that is over 100 thousands and somewhat heavier than the frame rails they connect to.
Thankssss buddy.
My stock bumper brackets are at least 3/8", maybe thicker.
No, they are twice that at the frame. I just installed the front and they are at least 3/8" thick where they bolt to the bumper, probably thicker and they are heavy!Maybe where they overlap each other at the frame.
The 2 org brackets that mount bumper,to body ,I am useig now,do you sNo way. 1/8" is only .125" thick. No way in hell would I use that for bumper brackets.
Thats what i am useing now,org bumper to body brackets there are 2 holes to mount 70-72 mount at valance,74 only 1 hole to mount,thusssssss i have to make up the last hole hence the bracket i have fabe up to mount to the frame.No, they are twice that at the frame. I just installed the front and they are at least 3/8" thick where they bolt to the bumper, probably thicker and they are heavy!
Yes stock pieces for sure,i went with what you said,i must say i am glad i found what you did,wayyyyyyyyyyyyyyy better.Thankssssssssssss.That's what I should have done when I made my conversion bracket for my '74 to '70-'73 bumper swap. Looks good!
Did you make the brackets that bolt to the bumper as well, or are those stock pieces? Those are the ones I thought you were talking about. The bracket you made there is likely stronger than a '70-'73 mount, as on those cars the bumper just bolts to a couple layers of shetmetal (rear crossmember and frame tab).
Could you take some more pictures of this? I'm trying to do my 74 to 71 and a ran into mounting issues.
Are you useing the 72 org bumper brackets.Could you take some more pictures of this? I'm trying to do my 74 to 71 and a ran into mounting issues.
Yeah my bad I thought you were working on a dart, I must have read it wrongThe70 Dart is totally different than the Duster.
