1 bolt & 3 bolt cams
Pipedaddy
New Member
Warren MI
I have a 440 big block, can I use either a 1 or 3 bolt cam in it, or does the cam gear dictate which one to use.
single bolt for stock to medium performance, 3 bolt for higher performance higher revving applications. that's what i was told by my engine builder when i asked the same question.
From someone who had a freak bolt failure on a single bolt setup, I would never go with a single bolt again. They're ok to use if it is what you have, but if buying a cam and chain, I would always go with a 3-bolt.
That's Sprockets to you. Spacely Sprockets.
Off topic a little, but I bought a small Isky roller cam (R505-T) for a BB sight-unseen, and when it came in, it was single bolt. Also it was a cast core, so it needs no bronze intermediate shaft gear, perfect for the street. But how do you control the thrust, when a thrust button/roller would go where the central bolt is? I figured out a solution but haven't tried it yet. Thanks McMaster/Carr. LOL
