School me - Do modern flat tappet cams/lifters need high-zinc oil?
Done Swimmin
Canada
I have stroker planned based on a 400 block and with adjustable rockers, aluminum heads and i have reservations about rollers lifters. My engine builder wants to use mechanical or hydraulic flat tappets. Will I have to use a high zinc content oil even with modern cams/metalurgy and heat treating?
Absolutely. There are few things that you can do to increase the odds of success, the proper oil is at the top of that list.
"Even with modern cams and Metallurgy"?
Especially with modern cams and metallurgy, you must use high-zinc oil.
"Modern metallurgy" has gotten significantly more inconsistent.
Reconsider your reservations on using a roller cam- but whatever you do, do not compromise on the oil.
Zinc is in every engine oil. It has to be or it’s not engine oil.
Excess zinc is BAD.
Buying an oil and then adding zinc is BAD.
Very smart dudes (chics I’m sure so no one gets offended) spend decades learning tribology. They understand what happens to an oil when you add another ingredient which makes that ingredient out of proportion to the rest of the oil.
Buy a QUALITY engine oil designed to do what you need.
I don’t run “modern” oils in these older engines. I don’t run cats.
You can reduce your clearances and eliminate as many needless leaks as you can and use a “modern” grade of oil (notice I didn’t say weight) and I encourage that.
My rod bearing clearance is .0019-.0021 and my mains are .0021-.0024.
I’m going to use a racing 0w20 and it has detergents and other additives that make the oil streetable.
Zinc content is important but so is low or NO detergent.
All Torco oils have detergent and dispersant packages.
When I bought my piston rings Lake Speed and I were emailing and we were both struggling to get our thoughts together.
So he had me call him. We had two areas where there were questions.
One was why I am running full groove bearings and running Torco SR5r 0w20.
My bearing choice meant I needed more oil ring to deal with the rods slinging oil on the cylinder walls all the time. And BTW they are throwing oil on the camshaft too.
His other concern was running a “racing” oil on the street because most racing oils don’t have detergents in them and the dispersant packages aren’t as effective in his definition of racing oils.
Torco oil has a full detergent package. I told him that and he was a bit skeptical. He said I’ll call you back.
About 40 minutes later he called back and said it does have detergents so run it.
I was going to anyway because I already knew what he didn’t.
It's been shown that too much can wash the oil right off. Plus, low or no detergent is what I want.
Ok. It’s not the detergents fault. It’s the tribologist who built the oil.
I’ve never seen any evidence of detergent killing ring seal.
That is the real key Rob. The real problem that was found during the zinc fiasco back in the day was the detergent was washing the zinc away. It ended up being lore that you need a special zinc oil for these old engines. Any oil is fine these days as they’ve figured out the detergent problem and every manufacturer has that issue resolved. The oil geek guy has shown through real data high zinc oil versus a normal oil does not show any difference in particulates in the oil analysis on flat tapped engines.
That said you should absolutely use a special break in oil which is a high zinc and low detergent oil for the first oil change at 500 miles and probably the next one as well.
VR-1 10w-30 is my go to with flat tappet cams. It's the right amount of everything
I don’t get the low detergent oil.
Once the cam is broke in and the rings are seated (if it’s a roller cam engine the rings should be in by the time the engine is up to temperature) I get the break in oil of it.
You can see the power falling off because it’s a single grade oil and it’s done its job.
Torco says leave it in longer but my testing says that ain’t so.
Once that stuff is done the switch to a quality (Group IV/V base oils) oil ASAP.
Not low detergent oil. The additive detergent they were using then was causing the problems. They changed the detergent additives to something that did not wash the zinc off the surfaces.
I understand that. I don’t just grab a quote out of a statement by maybe I should.
I was asking about your last statement that the first oil change should be with a low detergent oil. I ask asking why about that.
No it should be dedicated break in oil (like Joe Gibbs) that tends to be low detergent typically (if is recall Lakes video correctly he developed the Joe Gibbs oils)
The point of detergent in oil is like in everything else. To keep it clean. No thanks. I'll do that myself by regularly changing my oil on time.
I certainly do not want to jinx myself..... but I've never lost a flat tappet cam
Sadly it never was a lack of zinc in the oil that was killing cams.
All engine oil has zinc in it.
The amount of zinc was reduced but it was never eliminated.
If an oil has 800 ppm of zinc or if it has 1500 ppm zinc when it comes out of the bottle doesn’t change anything.
The difference is the oil with less zinc will run out of zinc sooner.
It’s that basic.
