coffeedart67
I got a scarebird front brake kit and have all the parts I need coming. My question is at least one hub has a couple of the lug studs welded in. Should I just replace both hubs or have the studs and weld machined off and pressed out and replaced. To me since they were welded in indicates that they was not enough material left in the hub to hold the studs tightly so I would need to weld the new studs in.
![](http://i306.photobucket.com/albums/nn280/cshadow-2008/001-5.jpg)
Thanks
Aaron
Thanks
Aaron
