[WANTED] 10" Drum hub/spindles for A-body 66-72
xLURKxDOGx
"An angel fat, at satan's feast"
PHX
Looking for either 1 or a set. I bought a set from craigslist and it turns out 1 had a drum with lugs cast into it and the other was a slide off drum. I need the one where the drum comes off without the lugs. I found one at a junkyard but it must have been from a 9"??. Ive never seen this and im not sure if theyre hard to find??? Looking to do this this weekend and will pay to have this 2 day shipped if anyone has one.
Thanks again!!
... I need the one where the drum comes off without the lugs...
They did not come this way. You need to use a swage cutter to cut the drum from the swaged over studs. I have a set of front 10" drums and knuckles, but I do not think you need them.
I have these taken off of a Low miles restored 71 Demon 340 car. The backing plates are loaded with brake shoes and cylinders. I converted to SSBC disc brakes. I have sold the hubs. PM me if interested.
I need whats in picture 2 and 3 below the drum, if you will part with them??
Jake
Im looking for the hub that is in picture 2 and 3 below the drum that 72dart posted, if you do have them ill pay up for them since i am in a pickle :pale:
Why don't you just cut the swages off & use the hub ? The Mopar front drum assemblies were swaged together from the factory. I've seen the hub/drum assemblies separated and allowed to float....
I'm a bit confused as to what you need...Hmmm...PM sent.
Or just have the drum turned and run it?
Thanks for all the help!! These people are life savers!!! :cheers::prayer::prayer:
Jake
I am sorry for the confusion on what you needed. I should have edited the hubs out of those two pics because I sold them to another member here about a month ago. I thought you were interested in drums. Mike
