11 second "318" 4-door
Scroll down to the bottom. Clearly states its a stroker.
ENGINE
Brand:Chrysler 390ci stroker V8
Induction:Victor 340 intake, APD 950cfm
Heads:Steven Sun Castings/Speedmaster
Camshaft:Solid flat-tappet
Conrods:Scat I-beam
Pistons:Icon forged
Crank:Scat 4in stroker
Oil pump:Melling
Fuel system:Aeromotive
Cooling:Three-core factory, 16in Maradyne fan, Davies Craig controller
Exhaust:15/8in stepped tri-Y headers, twin 3in system
Ignition:MSD programmable 6AL2, Blaster 2 coil and leads
Click bait :) I get you were just playing around, but once you stroke sbm to 390-440+, It's basically a big block now and hard to give it under dog status, especially 318 under dog status.
Still, very nice car though.
basically a big block? except the low flow heads... small bore and criminally shrouded valves..... :)
Didn't say a great big block :) factory bbm wedge aren't known for there great ootb flow and also there is 900+ hp sbm heads available, but I get your point :)
I just find it weird when some get some kind of underdog satisfiction when say a stroker small block keeps up/beats a big block, when you built the short block to big block size and put a similar capable top end on it, why wouldn't it ?
i was joking around... i like small blocks.. just not mine :)
