22dog22
bought an 12 volt electric vacuum pump ,Comp Cams, due to low engine vacuum due to cam choice , have it wired in, power up car, unit calls for an 8-10 amp fuse [ seems low to me ] but I put in a 10amp fuse , fuse blew, double checked the relay circuit wiring to make sure is correct, could not find any problems, the only thing I could maybe see is the pressure switch is not grounded correctly, I will put a star type washer under the switch to make sure it is grounded the directions states if it is not grounded the unit will not work correctly [ nothing about popping a fuse] if that does not work I will try to battery test the motor, in case the motor is bad.
