122 tooth flywheel for early A's
moparlee
64 Valiant
Joplin, Mo
Hey guys, has anybody here fixed stripped pressure plate bolt hole in their flywheels before?
Thanks for your time.
The best fix is to drill six new holes...and what flywheel has 122 teeth?
early A-bodies 1966 and back used a 9-1/2" clutch with a 122 tooth flywheel
67 and later used the 10-1/2" clutch with a 130 tooth flywheel
many people upgrade to the later, bigger set up as the early smaller one kind of sucked
to do that you also need to change to a later 67 and up bellhousing and use an aftermarket conversion Z-bar http://www.brewersperformance.com/proddetail.asp?prod=TS636
Oh yeah...I forgot about the early itsy-bitsy wheels. My brain focused on one of the recent small wheels and thus confused the hell outa me...
