12v with key on
These are quite large pdf's You need to scrouge up a "real computer." Either that or you might bounce around ebay and see if you can find a reprint/ CD, or even old original for sale.
Frankly I cannot imagine attempting to view these on a tiny screen
My iPad allows for me to zoom PDFs and makes it easier for me to read it viewing them on an iPhone would suck but not the iPad
Is there any reason I can’t take the 12v keyed leg and just wire it through a switch and wire it to the Blue sea fuse box I added instead?
You lost me..........If you are asking what I think, !!NO!! LOL
You need something that will handle the amperage that the new fuse panel will supply to whatever you are connecting to IT
The ignition circuit "switched 12" was NEVER intended to supply very much current, and the accessory circuit is nearly overloaded as well. Therefore you need to take your "switched 12" and key a relay, and feed the new box, that is, assuming that everything the new box feeds is to be switched with the key
"Just how much" total current are we talking about, here? That is the first question
Second, if it's quite a bit, you really don't want to supply the relay power off the current ammeter circuit. Pull power off something like the starter relay.
You will have to pick a relay/ solenoid that will handle the current you want to pull
Ok let me back up, my Demon isn’t stock... I have switches (ie racecar stuff) to run my ignition box, fuel pump, water pump, gauge lights etc. so my question is can I just wire the “12v keyed leg” to a switch powered from the Blue Sea fuse box
