[SOLD] 14" large bolt pattern steel wheel with good bias ply tire
bbrroowwnn
never re member
Drums, PA
14" large bolt pattern steel wheel with good bias ply tire....this was pulled from a trunk.....excellent thread on tire....no dry rotting....holding air for months now......no leaks...... this is the 5 on 4-1/2 bolt pattern....tire is a good year polyester cord power cushion size 6.95-14.....make a great spare for your car....asking 50.00...prefer local pickup only....
By chance is it 5.5 inches wide and the center section where the dog dish would go be 10 inches across. Appears to be 9 but wanted to check.
I bought a 70 340 duster in a barn on west foothill road in Drums. was in there since 79.
Are you intersted in trading for the tires and wheels.I have many parts. And not far from you.
A little more info on the date codes.... K-2-4 A 2 near the lug nut holes...I believe I got this from a 1974 valiant trunk
5.5 inches wide and only 9 inches for dog dish
LOL, this is getting bumped as much as your cartoon girl's.......... ahem...
Are you measuring the 5.5" the outer edges of the lips of the rim or trying to measure/estimate this width where the tires bead seal? (The latter is the right way..)
BTW, I am pretty sure the '63 Fury (B body) used the 4.5" diameter pattern.
I could use a 5" wide rim of this type.....but the dish diameter is too small.
Estimating where the tire bead seals
