There was also a company making 17" alloy wheels in 5x4", for ~$170 ea. Search for posts here. Many like the rubber-band tires of new cars, though some down-sides (wheels crack, harsher ride). You can save a lot by getting used wheels. So many change to BBP that you can find deals on SBP. I have a set of Cragars and mag slotted. My 64 Valiant even came with newish spoke wheels, though I don't trust the adapter (from 5 studs to a single large spinny nut). Re width, decide if you want wider in the rear. I recall, my Cragars are 6" wide all around. The slotted mags are ~6" wide front and real wide (10"?) rear. Fit fine in my 65 Dart w/o tubbing the sheet-metal or moving the leaf springs.
