[SOLD] 14x7" Aluminum Slots, small bolt pattern
72bluNblu
NorCal
I have 4 14x7" small bolt pattern aluminum slot wheels. Backspace on all 4 is 3.25". They're really 2 different pairs if you look closely, the set with the tires still mounted are definitely older. The style of the slot is slightly different if you look really hard.
Asking $200 for the set, I will separate into the matched pairs for $100 per pair.
I can ship, and I can have the tires unmounted for shipping. The tires are 245/60/14's, but there's no date code so they're over 10 years old and shouldn't be used as anything beyond rollers anyway. Shipping will be at they buyer's expense and will probably be pretty pricey. Pick up available Sacramento, CA. I prefer PayPal for payment if I'm shipping.
PM for more info, I have more pictures if you want more detailed shots.
Front and back of the first pair
Front and back of the second pair
Shipping without tires to 96750 ?
To Hawaii? :eek:
Even by USPS it will be about $192. They have to go in two separate packages, 2 rims a piece, for about $96 per package. The rims are 20 lbs a piece, plus a few pounds per rim for packaging. They're obviously not packed up yet, but I can't see it being much, if any, less than that.
ok thanks, Little more than I want to spend. Any A body LBP axles ?
Yeah I understand, even shipping to the lower 48 won't be cheap. Shipping to Hawaii is crazy though! Ouch.
Sorry, no LBP A-body axles.
Bump!
Shipping to anywhere other than Hawaii (or maybe Alaska) should be quite a bit better than the scary quotes above :eek:. I can also ship via Greyhound or Fastenal. I'm pretty familiar with shipping via Greyhound, I haven't shipped Fastenal before but I do have a couple of stores within reasonable driving distance so if it'll help I'd do it.
