DrCharles
Doesn't anyone make a 15x10 steel wheel (4.5" bolt pattern) with a 7.25" backspace any more?
I have stock front steelies with 195/70-14 tires that take a dog dish cap.
But my rears don't match the front since they are a widened pair of rally wheels, and are 8" backspace (a bit close on the inside, originally intended for a B-body width housing). Got 'em cheap when I still had the wider 8-3/4
So ideally I'd like a stock appearing 15" wheel that will also take dog dish caps. Any place you'd recommend (forget Stockton Wheel unless they have made major changes to service and attitude in the last few years)?
The other option is to replace all four with matching aluminum but that will be expensive, and I'm trying to keep a low profile (at least until I start the engine)
No caps at the moment because fronts-only would look worse!
