15x7 Rally,s on rear of 66 Dart
pettybludart
Ontario,Canada
What,s the biggest meats I can tuck in the wheelwell of a 66 Dart??No mini-tub,no spring relocation?Any help would be appreaciated,gotta get this car on the ground.Thanks.
I fit 245x60x14's on a Mopar steely 14x5.5 (small bolt pattern) on my 66.
That is actually the same tire/rim on the red 64 in my avatar. I put them on both to see how they looked.
Fit nicely with no rubbing.
Thank You!
OldMoparsRule!
Thanks Oldmoparsrule,I,ve swapped out the 7 1/4 sbp and put in a 8 3/4 bbp with Moser axels.I found some 15x7 bbp rallys that I,d like to use with 14x6 rallys up front.Still looking for the biggest 15 inch tire I can fit in there?
I had 255/60/15's on 15X7 mopar steelies 4 1/4bs, on a 64 Dart w/super stock springs. You have room on the inside, maybe 1", outside is close..
Bob
