72lidart
Member
I purchased a set of 15 x 7 steel wheels with 4.25 backspacing. I know that they will fit the rears will i have any problems with the fronts. Any ideas of what size rubber I should go with. I really want to use BFG radial TA.
rumblefish, your tire is wider and taller than stock. as long as you go with a lower profile when you get a wider tire you should be ok. id think u could fit a 225/50 or 55 on there and still have a decent sidewall. use a tire calculator to help with sizing
Stock size is 205-70-14. When the time comes, I'll be looking to stuff the rear, not so mouch the front.I have 215/70/14's on the front of my Duster
