17x8 show wheels streeter
Dartemus
1971 4-door Dart Classic
Clovis, CA
Wheels have 0 offset. Correct 5on4 bolt pattern. Call in and they Say they will work on 71 dart.
What tire combo Will I need? Smart to stagger (I like the look)
Stock 1971 dart 4 door with drums
Make sure the wheels are actually in their building, I ordered a set was told thirty days out... we are now on day 74!
A 8 inch wide wheel with zero offset to the inside, suggests 8 inches of rim to clean on the show side. If that's the case, Not for me. Notice new car/truck wheels have a lot less surface for brake dust, etc., to accumulate on.
That's interesting. They usually have them in stock and then throw them on a CNC to drill the bolt pattern.
As far as tire size, Motech performance recommended a 215/45/17 for the front and a 245/45/17 for the rear.
Have 225/50 on back and 205/50 on front.
Tried to go same size all the way around and would have been at the 205s... so beefed the back a tad.
Thanks all.
dart with streeters
