18-4067 / 18-4068 Calipers
Mcfarlrm
Florida
Looking for the correct/recommended street application brake pads for these calipers whether its ceramic, semi-metallic, organic, etc.
Not sure what you mean by correct. Which ever you can find that do the least damage to the rotor. Seems that semi metallic is common and reasonably priced
i like semi-metallic for street applications-- or at least the types of streets i drive. organics if you have high dollar rotors that you don't want to roach.
EBC makes some really nice pads for the slider calipers but they are spendy.
It depends on what you think is most important. Priority on quickest stopping, rotor life, noise, pad dust, and cost can all figure into your decision.
I've used semi-metallic since the '70s because they stop well and are relatively inexpensive. But they can be noisier, dirtier and harder on rotors (*edit - and drums, which was what I had in the '70s!) than the expensive pads.
