1867 Barracuda Speedometer Problems
bmxican
Mopar Aficionado
Vista, CA
OK, so my Cuda's spedo isn't working. I looked under the dash and the cable was just undone. When I screwed it into the dash and started the car, it started jumping up and down and making noises (the speedometer, not the car :toothy10:)...
Where can I get the spedo fixed? (If that is the problem).
EDIT: DAMN IT! HAHA. WRONG DATE.
1867 Huh. I wasn't aware they started making them at that time haha. I couldn't resist lol.
cable could need to be lubed or it could be kinked. Also the speedo head could need lube too but my guess it is the cable.
I´ll try to grease it and re-connect it and see if this solves the problem.
Thanks!
Use powdered graphite to lube speedo cable. It'll flow lots better than petroleum grease. Hardware store or locksmiths should have it.
