[FOR SALE] 1962 Plymouth Valiant for restoration
Shanikosh
New Member
Broadway
Rating - 0%
0   0   0
Good Day
If the motor is a 225, I would be interested in the road draft tube. Shipping to 43567 (NW Ohio).
The road draft tube is located in the valve cover (top of the engine) at the rear. It is a piece of tubing with a cap (valve cover end) and is secured with one bolt towards the bottom.
To tell if the motor is a 225, look at the water pump. There should be a short piece of hose that connects the pump to the head. The hose length should be approximately 2 inches long. If it is very short (approximately 1 inch the motor is a 170.
Thanks for your time.
Omni
I do not have a title for the valiant, sorry.
Also, I will investigate and get back to you about the road draft tube.
Thanks!
