[WANTED] 1963-1966 Dart Wagon/Barracuda quarter panel patch
m880cummins
Parkesburg, PA
Rating - 0%
0   0   0
Hi Guys,
Probably a long shot but I need a passenger side rear quarter panel from a 1963-65 Barracuda or 63-66 dart wagon. Restoring my 1966 wagon and I am almost done with metal work but the existing quarter panel is too mangled to save. Rust wise, it isn't bad (Texas Car) but it was hit hard. I know the barracuda does not have the same exact quarter panel but I just need a piece from the wheel well to the bumper and upper body line to the bottom. I just need something to work with. A little rust is ok just need something straight.
Here's what I am working with. It is better now than it was in this picture but there is just too many dents and pin holes in the bottom to bother with. Trying not to load up this car with bondo. This would be the only area on the car needing anything more than a skim of filler here and there.
Thanks
Charlie
Barracuda has a longer spear but I can fix you up either way. Convertible and wagon are the same and barracuda and valiant can be made to work.
toomanymopars is first here, but this is what regular valiant four door looks like. Am guessing it has different body lines than dart in this area. this one is pretty rough anyway, trapped sand in lower quarter drop offs rusted out bottom of quarters and RR corner has been hit. LR corner is much better in tail light area.
