[SOLD] 1964 Valiant Barracuda Instrument Panel Gauge Cluster
ZooKypr
NJ
1964 Valiant / Barracuda Instrument Panel Gauge Cluster
Has four gauges - Speedometer - Fuel - Alternator - Temperature
also has Ignition Switch & Key
Was working when pulled and stored away several years ago. Not sure how to test it so I can't gaurantee if it works now. Sold As Is.
Price - 80.00 + shipping, PM me Worldwide
PayPal (add 4% fees) or USPS money order only
I'll pass, its in the same shape as the ones I have. Thanks for the pics!
are the pins all good on the back side-- hard to tell with the pic? thanks
Not sure which pins your referring too but does this pic help?
Pins refer to the cluster of pins that the wiring plugs into, it is a main connection of the cluster.?your item appears to have broken/ missing pins which needs repair to make your unit functional. That is if the gauges are any good, which they might not be since the pins are broken. Lawrence
