1964 Valiant steering wheel wiring diagram
HR5058
Eldridge, Iowa
Anyone have a color coded wiring diagram for the wires that come out of the bottom of the steering diagram? I am trying to adapt a Kwik Wire wiring kit to my valiant. Thanks.
HR5058
Eldridge, Iowa
Any help all would be appreciated. I thought I had it figured out but nope. For clarification, I am hoping someone has what color each goes to for the turn signal, horn, etc that goes up through the steering wheel shaft housing. There are 9 wires on the loom. Pic attached
Jim Kueneman
Sonoita, Az
(1) Light Green LF turnsignal
(2) 12V from the flasher
(3) Tan RF turnsignal
(4) Black-White tracer Horn
(5) Orange 12V accessory (any courtesy bulbs in the column)
(6) Dark Green RF turnsignal
(7) White to brake light switch
(8) Brown RF turnsignal
(9) probably unused
(10) probably unused
cudamark
San Diego
double light green is left front turn signal and dash indicator
dark green is left rear turn signal
white is brake light switch
red is turn signal flasher
double tan is right front turn signal and dash indicator
brown is right rear turn signal
black with tracer is horn relay
