BartHoleMy
Member
340 motor ('72 X heads, solid lifters withextra set of rockers, Edelbrock rpm air gap intake, mopar electronic ignition) Holley 4 barrel (no choke, dual feed, mechanical accelerator pumps), Ron Davis radiator, clutch fan, 904 single cable automatic with low first gear, slip yoke drive shaft no ball and trunion, Hurst 1/4 stick shifter, Autometer gauges, 8 3/4 rear end from 72 Dart with Detroit Eaton locker, Willwood brakes front and rear, battery moved to RR trunk, Recaro Pole Position seats, Schroth four point harness, HDK front subframe with QA1 double adjustable coilover in front and rear shocks, rack steering, front swaybay, 16x8 crager steel wheels, side windows are out for weatherstriping replacement, have all trim except rocker and drip rail, badge delete, front bumper delete, charging system and battery wiring enlarged, high torque starter, have an extra 273 block and forged crank among other parts and spares, motor is very quick 65mph+, likes rpm, car handles like it's on rails for a muscle car
La Quinta, CA
$13,000
La Quinta, CA
$13,000
