[FOR SALE] 1965 barracuda commando 4spd.
Hippylong
Active Member
Fresno
Rating - 0%
0   0   0
Here ya go bro's and sisters
aTrue California car.
1965 barracuda commando factory h 4 speed. I believe its all original except steering wheel. Has original exhaust.
I purchased it from a person whome has passed away. He was a machinist. All Original paint except in Engine bay and door / trunk jams repainted. Interior all there but stiff. Stored its whole life after first owner. Rear bumper needs rechromed. No keys.
Bill of sale clean. $18.500
Its in fresno, ca. 93703
I locked the stupid trunk.. uggh.
Anyways I feel obligated to get this into proper hands.
Somewhat unusual.
...and very cool.
Wonder if it has other "s" options?
I believe a Formula S would have a "2" under the "C".
That was a quick lookup.
Decoding the rest of the tag would be interesting.
I'm mainly a 66-74 guy, and I don't know all of the pre 66 stuff (and not even all the 66 stuff).
Not a Formula S
In the alphabet row, it would need to have the number 2 under the letter C.
The 31 under the AB does signify a 273-4 barrel.
Check out this document:
http://www.earlycuda.org/techdocs/6265FenderTagDecode.pdf
Some fender tags may have an S shaped hole punched in them. This is an inspection punch stamp. It has no meaning other than an inspector at that factory did his or her job and inspected the car that day.
Power brakes?
That's interesting.
Only seen a handfull of those.
Does have a scuff plate on the hump for the accelerator peddle.
Can you post some under carriage pictures... floor pans, rear, exhaust, suspension. have you tried to get into the trunk via the divider panel. You could then pop the trunk.
Sure can.. I can't reach the splitter because the trunk is filled with parts..
I can't fit under today. I will try and jack it up this weekend. heres what I could reach now.
Here's underside and fenderwells of the barracuda. All clean clean. The bumper needs rechromed. Im working on getting keys made.
View attachment 1715737177 View attachment 1715737178 View attachment 1715737179 View attachment 1715737180 View attachment 1715737181 View attachment 1715737182 View attachment 1715737183 View attachment 1715737184 View attachment 1715737185
View attachment 1715737316[/QUOTE. It is a Rallye Pack car. Does it have 13 " wheels. Came w/out tach and front sway bar unless options added.
