1965 Barracuda Formula S rear defroster
Early A-Body Discussions
  1. FWDLK Frank
    FWDLK Frank Well-Known Member
    138
    61
    Aug 7, 2014
    Baltimore
    Local Time:
    10:06 PM
    Hello,
    Anyone out there have a factory formula S with a factory rear defroster? I'm interested as to where the switch was mounted. Pictures would be amazing. Thanks in advance!:prayer:
    -Frank
  2. 66340SEDAN
    66340SEDAN FABO Member #3649 FABO Gold Member
    21,728
    11697
    Nov 20, 2006
    Minnesota
    Local Time:
    9:06 PM
    I pulled one from a 65 awhile back, I might have pics of it before I yanked it but I think it mounted to the under side of the dash, possibly to the left side of the steering column
  3. FWDLK Frank
    138
    61
    Aug 7, 2014
    Baltimore
    Local Time:
    10:06 PM
    If you have pics, that would be great. They're normally mounted where the tach resides but if you have the tach, what to do? Let me know and thanks!
  4. Tadams
    Tadams Tadams
    3,643
    1489
    Jun 13, 2008
    nc
    Local Time:
    10:06 PM
    No pictures, I'm at work. Mine had a switch in the dash under the radio that simply turned on of off.
  5. 64_Barracuda
    64_Barracuda Virginia Beach VA
    800
    28
    Jul 29, 2005
    Virginia Beach, VA USA
    Local Time:
    10:06 PM
    So the way I have seen them,
    If it was non tach no a/c it was where the tach goes.
    If it was tach it could be under radio
    If it was tach a/c car it was under tach but out of way of e-brake
    I would call Wildcat Autowrecking and see if they can help you.
    The switch was the same from 64-66 same as convertible top in Valiants.
  6. FWDLK Frank
    138
    61
    Aug 7, 2014
    Baltimore
    Local Time:
    10:06 PM
    Thank you for the info. Hopefully 66340 will be able to provide a picture. I have some ideas but I want it to look 100% factory. Thanks again!
    Frank
