[WANTED] 1965 Barracuda front wheel hub.
'65-72 will work. If you get a hub with a good drum, it might save you a bit of time and money. Stock, it was LH thread studs on the driver's side and RH thread studs on the passenger side (from '65-70). '71-2 were RH on both sides. A LH will work on the right hand however, just change the studs or get the correct lug nuts with it......and remember it when it comes to pulling that wheel next time!
Since no one has any offers on the table, I've got a couple of 10" drums with issues but with hubs! First up, this one has 2 broken studs and actually measures under 10". I've never seen one less than 10" but here it is.
This one has had the weight knocked off, probably interfered with aftermarket wheels. It measures 10.060 that has .030 to go.
