BarracudaDave
I am currently replacing all brake lines on my 65 Barracuda. The car was already converted to front disk (yeaaaa). I plan on keeping it a manual brake car. For safety, I am converting the master cylinder from a single reservoir to a dual reservoir.
Two problems that I could use some help with:
1) I keep ordering Cardone 101326 - disk/drum 1 inch bore. (I would prefer a 7/8 inch or 15/16 inch bore but I can't find one. They may not move enough fluid for disk??) The picture of the unit from Cardone shows a larger reservoir for the front disk. Unfortunately, O'Reilly's keeps getting equal size reservoirs for a drum/drum application. They were nice enough to have someone at the warehouse open all of the boxes and they were all drum/drum?? If I have to, I'll settle for the equal size reservoirs. I guess I just have to keep an eye on the brake fluid level. Any other recomendations for a m/c that will work?
2) New master cylinders do not come with push rods? It does not appear that my current push rod is compatible with Cardone 10-1326 or any other disk/drum m/c. Other than a junk yard, are any available. It would be a lot easier if the m/c's came with push rods! If someone has a compatible m/c w/ push rod available, I would be interested.
Any input would be helpful. Thanks!
:blob:
:blob:
