1965 Dart Wagon Vendors
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I thought I’d pass along some of the vendors I’ve used because their products fit and look correct in the restoration and modification of my 65 Dart wagon. Some of the parts are year/model-specific; a lot of parts can be used on other years and models of Mopars. Hope this list will help other 65 (and early A wagon owners) so, In no particular order:
DMT - hood to cowl seal, hood to radiator seal, fender splash shields, AC/Heater box rebuild kit, sedan door catwhiskers
REM - hood pad
Phoenix Specialty Coatings - restore Charger 273/Commando valve covers
and coat numerous small parts
Legendary - seat covers and bucket seat foam
Laysons - patch panels for lower fenders, parch panels for lower quarter panels (modified to fit the wagon), sill plates, carpet hold downs, inside door emblems, 65 Dart-only exterior hash emblems
Restoration Specialties - division bar channel, door gkass run channel, door windlace (door seal), tailgate seal
Auto Body Specialties - front and rear floor pans
Dakota Digital - custom instrument cluster
Joe Suchy - tailgate lower window seal and upper window seal (as a kit) and roof rack rail protective rubber seals
Auto Custom Carpet - carperting
Eric Manual - nuts, bolts and general hardware refinisher to correct finish
Ulf 65dartcharger was who recommended him to me. Thanks Ulf!
Tri City Plating - bumper and plating services
Ulf Andersoon - reproduction Charger 273 pie pan
Helwig - sway bar
Rock Auto - 73-76 A Body disc brake rotors, seals and bearings, and brake hoses
Power Brake Booster Exchange aka Booster Dewey - rebuilder of power brake boosters
Classic Air (now closed) - restore AC lines, rebuild compressors and driers
QA1 - adjustable strut rods
eBay - NOS Moog ball joints and tie rod ends
Slant Six Dan - provided NOS 73-76 disc brake calipers
Steer and Gear - power steering box and pump rebuilder with upgrade options
PST - 1.03 torsion bars
ProFornance transmission (a division of Dynamic Converters) - rebuilder of 727, 904 and modern Mopar Overdrive transmissions, custom torque converters
Performance Online - aluminum master cylinder (4 bolt style)
M & H Electrical - reproduction positive snd negative battery cables
Feel free to list vendors whose parts work and fit your early A wagon
Sticky! Well done. This is great information and these vendors may have a lot of parts for other early A models. Thanks for listing.
REM - hood pad
Helwig - sway bar
Don! Did you get your 64 to 66 brake booster rebuilt by Nooster Dewey?
Ulf I am using a 68 or so disc brake booster which they did rebuild and did the dichromate finish on the booster and pair of braces. I talked directly wiith “Booster Dewey” several years ago about rebuilding the 64-66 booster. At tgat time he said it was no problem. I would call them and see if that’s still the case.
That would be awesome.
