dibbons
Looking at old photos ballast resisitor must have been on the cowl, above the hood tension rods. Is that the factory location for a vehicle like mine? Thank you.
Yes, you are right. I have it on 3 Dart 65s!!
I found two holes directly behind the power brake booster and two screws in a sandwich bag with a note (I made the note almost 3 years ago) they belong behind the power booster on the firewall. There is no notation whether the two holes or screws serve any purpose.
I have that on my Dart Charger hardtop and the convertible too.I found my horn relay attached to the bracket of the power brake booster with two small bolts/nuts.
Your upper picture shows the bulkhead connector position. By your picture I can say this is a later produced car. Which date was your car assembled?While we are on it, maybe we kind find what these two "mystery" holes are in the upper firewall just below the seam, one on driver's side and one on passenger side (see green tape). Thank you again.
Thats were it is on my 66 Dart with A/CLooking at old photos ballast resisitor must have been on the cowl, above the hood tension rods. Is that the factory location for a vehicle like mine? Thank you.
