Welcome to FABO there, Bob! This swap has been done many times here, and is a common swap to do! You will need things like the V8 center link which has a drop to clear the V8 oil pan! You will also be looking for the V8 throttle cable setup which is cable operated instead of linkage, a set of V8 motor mounts for the early style K frame, a small block trans from a 64-5 car as they are cable operated, which changed in 66, and the slanty one will not mate to a V8! You may also want to change to the 22" radiator if your car is running the 19", the correct set of pulleys and timing cover for your motor, depending on which year motor you find! There was a change in the radiator inlet and outlet location in 1970 and later small blocks that may play into the water pump style you use with your radiator.
That's about the gist of the swap, and I may have forgotten a few details, but that is the bulk of the items anyway!! Good luck with your project, and enjoy the ride!! Geof
