1965 valiant gas cap
augiepaw
Roy, Ut.
Hey, would anyone know where I can find a gas cap for a 65' Valiant? I look about most every where and came up empty.
daimrader makes an aluminum cap & SlantSixDan had some originals repo'd-- both very good pieces ,Lawrence
damraider makes a good cap for cheap. Paint it to match the car and nobody will ever know...
There was a nice milled aluminum one on ebay for $35 I was watching (might be same damraider piece), since my 65 Dart came w/ an after-market locking gas cap. I recall a new racer-type flip cap, similar to what came on some 'cuda's or challengers, and might fit.
Thanks guys !! Yes, still making these caps . Here is the Ebay # 271264375549 .
Thanks again,
Steve
Someone (can't remember who) on the site was making adapters to fit both early and later A's to use a flip cap.
The member's user name is 4mulaSvaliant and the thread is here...
ww.forabodiesonly.com/mopar/showthread.php?t=53282&highlight=flip+top+gas+cap+adapter
I found a solution for the gas cap. While at the local junk yard this weekend, I pulled the filler tube and cap out of an early 70’s Dodge truck for $8.00. took it home and in about an hour I had the problem taken care of. I pulled the filler tube out of the Valiant and cut about an inch off of the cap end. Then cut the truck filler tube about an inch and a half from the cap end. I had to expand the pipe a little so the slipped over each other. After putting things together and making sure everything lined up so the handle on the cap was level, I marked it and pulled it out. Soldered it together, then put it back in the Valiant. For $8.00 and a hour I now have a gas cap that looks original, that’s not obsolete and all I have to do is remember if I need another cap is to get one for a 78’ truck. Since all the work is done under the quarter panel and the jack is there, you have to stick your head down and look for it to see It.
Brilliant!! I love a cheap, elegant solution like this. Jealous 'cause I didn't think of this when the cap for my old '66 Valiant got run over by 2 lanes of traffic before I could retrieve it. Thanks for sharing and letting us know how this turned out...
It turned out better than I thought. Things don't go this smooth. The only thing I had to becareful of, since the factory had already soldered the vent tube there, was to make sure I didn't get to much heat on it to unsolder that joint.
