[SOLD] 1966 273 engine parts
68 CUDA FORMULA S
Clarkston Michigan
I have a 1966 273 2 bbl intake, the thermostat housing, the timing chain cover and the harmonic balancer that were used to dress up the 318 that I had in the barracuda when I first put it together. The 1966 273 has now been put back together and has been re-installed back into my barracuda and the 318 is now going into the 1974 Scamp that I am building so I no longer need these duplicate parts. The intake, balancer, and thermostat housing are in good shape, the timing cover has some small pitting on the top and by the fuel pump area, please look at the pictures. I would like to get $100.00 for the whole lot, but shipping with that intake will probably be a little expensive. So if you are interested in them P.M. me and I will box them up and get a shipping quote for you. The thermostat housing is not pictured but is included, and I also have the timing tab that will go with it also.
Thanks
Bob
Somebody please chime in, I thought all the 273 balancer's were the same fit. If the 66 is different please let us know why.
Thanks
Bob
To answer the question, the 64 - 67 273's had forged cranks, so the balance should be the same and the dampers interchangeable...
