Jim, I sent my A 100 box off to " Lares ". Only place I could find that said they would rebuild it. Over $700 and when it came back it was just as sloppy as the one I sent them ! I would avoid them to say the least.
Sorry I still don’t like doing this stuff but the donut dolly made it a bit easier. Sixteen gauge is a handfull. Hinge braces reinforced and welded stiff. I should have shot epoxy so I could weld it up and roll the lip tomorrow but it’s windy and I’m spent.
I have been happy with Lares on Conventional Mopar pumps and Gearboxes. But i have had Two Different A-100 boxes done by other vendors and was not Happy.(More play than i was expecting).If Lares is Shitty with these ,then who is available ? Steer n Gear ? I believe the problem is Lack of parts and Demand for the '64-'70 A-100 Steering gear.Jim, I sent my A 100 box off to " Lares ". Only place I could find that said they would rebuild it. Over $700 and when it came back it was just as sloppy as the one I sent them ! I would avoid them to
Just spitballin here, but have you thought about something like this?
[/URL]
Hopefully can find seals to fit that steering box. Gonna need good steering when you stomp that gas pedal down with that 408 with headers.....
Curious as to what water/heater valve you are going to use.
Mine was too, and I looked for years for an NOS one. I had to go with this.
They look as good as my NOS gauges![]()
[May be awhile until Google Drives finishes processing these]
How do thermal gauges work anyway....
Mostly finished and the test out.
Thanks for posting that. Those look identical to the ones on my '66 Dart. Turns out, a couple of mine are busted. This certainly beats tack welding a nut like I was planning.My headlight adjusters came in from Shapeways. Yep they are the same as a 1966 A-Body and fit perfectly. Make sure you run the tap in and out a dozen times and the screw in and out a dozen times to make sure the plastic is fully cut and the screws won’t bind but other than that took longer to pick up the tools and do the job. You can get these on my ShapeWay store. I don’t mark them up at all. The cost is what the unit cost is.
Mustangpeak Designs by fbfdc26 - Shapeways Shops
