Most of the cars have the same issue. Exactly what you are experiencing so finding used parts might be tough. Most parts cars will probably have the same issues. I got a section from Desert Valley Auto Parts in Arizona and after sanding and blasting it had a lot of pinholes in it. I did use the trunk drops because they were's reproduced. You may end up buying more than you want to get what you need.
