[WANTED] 1966 Barracuda Throttle forward adjustable accelerator rod
CudaBrain
Active Member
Denver, CO
Rating - 0%
0   0   0
Looking for a forward adjustable accelerator rod for a 1966 Barracuda/Valiant. I am fairly sure it is the same for 2bbl and 4bbl.
Thanks in advance,
CudaBrain
Thanks in advance,
CudaBrain
I assume you mean the forward kickdown rod for the automatic transmission? If so, they are different between the 2bbl and 4bbl as an assembly. It's mainly the end that snaps onto the carb ball stud that's different. (it's longer on the 4bbl).
Still looking for that adjustable rod. Whether it is for the automatic kickdown assembly or the accelerator assembly, I still need it. Also, if anyone as the end piece that goes withe the 4 bbl, that would be great!!
