1966 cuda/2001 dodge 360 engine
nickker@aol.com
New Member
am in the process of replacing the 273 engine in my 1966 cuda with a 2001 360 engine from a dodge pickup. motor mounts from the 273 almost fit but the mounts have the three mounting holes reversed. is there a factory mount i can buy or do i have to weld plates on the originals and make fit? any help on this will be much appreciated.
thanks a body buds,
nick
You can weld up the original 273 mounts, you'll need some spacers or washers on at least 1 side. Thats what I did with mine. You can also buy Schumacher conversion mounts.
