ronw
What is the best maker of repair panels for a 1966 Dodge Dart GT Lt and RT wheel arch and lower quarters?
Hi Mike, I'm wondering if you know if the 67 drop off will work if you just use the bottom portion and not the entire drop off from the trunk. My extension are rotted only at the bottom and about half way back so I was hoping I could use the 67 extensions as patches. I enjoyed your thread by the way.Here's my body shop thread. A little rust repair
No one makes trunk floor extensions (drop off's) so you will need to either rebuild what you have or find some used ones.
Nope, not even close. 64 and 65 should work but I can't be 100% sure of that.Hi Mike, I'm wondering if you know if the 67 drop off will work if you just use the bottom portion and not the entire drop off from the trunk. My extension are rotted only at the bottom and about half way back so I was hoping I could use the 67 extensions as patches. I enjoyed your thread by the way.
Jay
Thanks for the reply guess it's junk yard or fabrication. They have a good amount of body panels but no one makes the 65/66 extensions still.Nope, not even close. 64 and 65 should work but I can't be 100% sure of that.
Exactly. I bought mine from Desert Valley Auto Parts.Thanks for the reply guess it's junk yard or fabrication. They have a good amount of body panels but no one makes the 65/66 extensions still.
@Lee Robinson can you help this fellow out?Thanks for the reply guess it's junk yard or fabrication. They have a good amount of body panels but no one makes the 65/66 extensions still.
I don't have any Dart drop offs at this time.@Lee Robinson can you help this fellow out?
Lee thanks for checking in.I don't have any Dart drop offs at this time.
