1966 dart motor mount..?
flathead31coupe
indianapolis indiana
I would like to know who has but a 440 into a factory /6.. 66 dart...what mounts were used...I bought a set of trans dapt mounts for this application...sorta.. the pass side works perfect, but the driver side would if the rubber mount was 2'' thicker...plus a little cutting is needed on the k frame to allow room for the oil filter...any thoughts...thinking about making a spacer to put on top of the rubber mount. sry didn't realize I had another like post started.......
I got a 66 dart 318, motor mounts that my mechanic used came off at 1966 plymouth dusters and they work perfectly. Can get them from NAPA 5$ a piece if thats what you're looking for.
??? Sorry, I don't follow you.
It looks like he wants to put a 440 in a 66 Dart. 318 mounts aren't the same and I was confused about the "came off at 1966 plymouth dusters and they work perfectly." I didn't understand.
